cmeilleur1337
- Joined
- Mar 30, 2017
- 6
Hey all. Just to revisit the facts from my last thread, I have a 1971 Merc 7.5 Hp ( red label) with bad electrical. From what I can tell at least 1 coil and the Stator are bad. Other then that the rest of the outboard is clean. I Picked this up as Parts for my 1974 7.5Hp Merc ( that is running fine) and decided I may as well put the work in to fix this one and have a spare.
So I left off the old thread stating that I could pickup a functioning power head from the same vintage for around 125 CAD. Well, I picked it up. It looks to be a blue label unit, possibly '76 or so. This is what the serial tells me, but wether or not the power head is original to the mount is any ones guess. It is missing the lower unit. Upon inspection, this unit has CDI ignition not points. A few Questions.
1. Will the entire power head fit onto the rest of the '71?
2. When installing the power head, are there specific requirements for the mating Gasket, or can I cut my own / use RTV sealant?
3. Failing number 1, Can the CDI ignition, coils and stator be put on the '71 power head?
I have started removing the power head from the '71, but am hung up on the mount for the throttle. On the '71 it is bolted to the power head, whereas the 76 it was bolted to the housing.
The 2 also use different style carbs, and choke mechanism. Which i do not foresee being a problem
Thoughts?
Thoughts?
