1971? Mercury 650 Lightning Outboard issues
DempseyGraham
Hi,
I believe I have a 1971 Merc 650 lightning. I am relatively new to boat motors so I am sorry if I use the wrong names. I am unsure of the year. The serial number and information are unreadable, they are located on the top ot the motor towards the back. First thing, I took the front cover off that the electronics mount to, because I wanted to clean the carbs. I didnt know how long it has been sitting. I never ended up cleaning the carbs because it is almost impossible to remove them without removing the distributor, and I didn't want to meas with timing. I got it started and seems to run fine, but water leaks out of the water cavity cover on the side of the motor. There is also a tiny bit of water around the top two spark plugs. I used a boroscope to look in the cylinders, and there was no water. I also did a compression test, and these are the results. From top to bottom cylinders 70 psi, 75p psi, 70 psi, 75 psi. I don't know what 2 stroke boat motor compression is supposed to be, but it seems good that they are all within 5 psi. So my questions are:
Where can I find either the manual as a pdf, or for free somewhere.
Where can I buy a gasket for the water cavity cover?
Has anyone had the same issue with the head, and water coming from the top?
Thank you!
The serial # is below the lower cowling at the front.-----Compression is way too low.----Test with another gauge.-----Install a new water pump impeller now.
jimmbo
That looks like a 68 or 69 Engine Cowl wrap, not a 71
The engine likely overheated at some point and some covers warped a bit and are now leaking.
It is also missing a few Parts
jimmbo
In that Day and Age the Serial Number would have been located just above the Tilt Tube, on the Yoke. It should also be on an Aluminium Plug, stuck in the Engine Block
Faztbullet
Unless you are restoring for sentimental reasons, find another project. That one can turn into a suck hole quickly!!!
