1971 Tecumseh AV750
Macm4352
Hey guys, could not find any info on this so hopefully it has not been covered 1000 times. I'm currently rebuilding a Tecumseh 2 cycle vertical av750-639-11. I been having zero luck finding a piston and rings. Is there anywhere other then the big name google search's I should be looking? Ideally I would find a gasket kit to but may be able to do without. Thanks in advance.
matt167
These were built with Techumseh/ Power Products lawnmower engines... Pistons/ rings/ gaskets can be found. You'll need a good lawnmower shop to find the right parts, but they are available. I forget how to search for the model numbers
brim_buster
Tecumseh has them. They have a website and all your Eska made outboards in early 70s used them on their 7hp motor.
Macm4352
Ok so maybe a stupid question I found the manual and part number but every site I visit that sells these engine parts say pistons and piston rings are no longer available. I have the part numbers just can’t find any that I can actually buy.
