1972 Mako 22' - Cleaning gas tank.
Saltymut
I have a 1972 Mako with a 51-gallon aluminum tank that has 3 year old gas in it. I just bought a new motor to mount and know the the gas has got to go. Removing the tank from the hull and replacing it with a new one is not an option, due to the T-Top and Center Console mounting position. The only alternative is to clean the existing tank. I tried to siphon the 1/2 tank (20 gallons) of gas out but the siphon hose I was using kept getting clogged with "white sludge". I've read several threads discussing certain chemicals that can be used to clean out the sludge from DIESEL tanks, but this one is gas. Are there any "cost effective" solutions to remove the old gas and have the tank clean again? The boat is being worked on in the Beaumont, TX area, so if I need to have it professionally done, are there any marine shops that can handle this? The winds are going to die down eventually and I've got to get into the blue waters soon....PLEASE HELP !!!!<br /><br />Thanks,<br />Saltymut
D
DJ
Guest
Re: 1972 Mako 22' - Cleaning gas tank.
Salty,<br /><br />You tank should have at least two access points.<br /><br />1. For the fuel filler/vent.<br /><br />2. One for the guage.<br /><br />If you remove the sending unit for the guage, the opening will be much larger and easier to access than the filler.<br />More than likely the sending unit is under a deck plate.
Saltymut
The tank has a "direct reading fuel guage" which is located directly under the center console in the stowage area. It is molded with the fiberglass deck.
Solittle
You should have a round 6" or so access plate on the floor directly over the sending unit.
Solittle
There is another way. Unhook the fuel line from the motor. Since the pick-up is at the bottom of the tank you might be able to use the fuel line as a siphon. If you are unable to get a flow, connect the end of the fuel line to an electric pump and pump it out into a container.<br /><br />I have read posts where this process (called scrubbing) is used on diesel tanks with the addition of a fuel filter and the fuel going right back into the tank it was pumped from.
Saltymut
Bingo !!!! Thanks SoLittle, That did the trick as far as removing the old gas from the tank. We filled several different sized gas containers with the old fuel, but now I guess I'll be doing some more research on this "scrubbing" technique. Anybody out there have some ideas on the way I should go about doing this? I would really like to find out if there is some type of chemical that needs to be "scrubbed" with. I remember somewhere reading something about using a high pressure pump?!?!?!<br /><br />Bryan
Solittle
There are a number of brands of fuel stabilizer that you can add to the fuel to "extend" it's life. <br /><br />As for now if I were you I would dispose of the fuel you got from the tank. Check with your county to see if they have any disposal sites for paint & fuel. I would also install a water seperator/fuel filter (looks like an auto oil filter) in the line from the tank to the motor if you do not already have one. That will prevent any residual crud from getting to your motor. And - check the filter once in a while.
Saltymut
Im already a step ahead of you on the water seperator. I just ordered one last week ( http://qualitymarinesurplus.com/SS Fuel water Sep..jpg ). It should be here in time before Memorial weekend. As far as the fuel filters go, I'm guessing the best "econimical" route would be to buy a handfull (or two hadfulls) of inline filters from Academy. It seems like common sense that it (fuel filter) should be placed BEFORE the water seperator. Am I right? I really appreciate the input.<br /><br />Bryan
wezie
The water separator is a filter with a reservoir for the water to separate out. The water will be in the bottom of the can when you check or replace the filter, which you will do a lot after you get everything clean and ready to go. Do not forget to clean or replace the fuel line itself. Buying more filter elements and changing them frequently initially may be a better way to go than the in line filters.<br />Adding more filters inline may be too much of a good thing. You will have to ask around some more about that. If you slow the fuel flow too much the engine will run lean and that creates heat and that is not good for aluminum engines.<br />Please make sure you got all the debris from the tank before you take off. If you rush this, you will forever have problems. <br />Good Luck.
Solittle
When you go to replace a filter take the old one off and pour the contents into a clean glass jar and have a look see.
kburks1230
Regarding the Fuel/Water separator. I HIGHLY SUGGEST! going with a Racor which has a clear bowl at the bottom and the little finger-twistable nozzle. I have the 3213 with the clear bowl. Without the clear bowl you won't be able to see if your filter is full of water. With the new ethanol fuel mixture combined with not having your tank completely full 100% of the time you are bound to fill that sucker up with water and not know it. I was just out last week and when the engine stopped dead about a half mile from the boat ramp. I looked down and my Racor fuel/water separator was completely full of water and my fuel line back to the engine was also completely full of water! I hadn't emptied it since the last trip out. I disconnected the line from the engine, emptied the racor bowl using the nozzle, pumped the ball back up and pumped out the excess water in the line until I saw gas again. I was back up and running in 10-15 minutes while on the water when otherwise i wouldn't have had a clue! Sometimes I empty about a half cup of water after a full day of running. From what I understand you will always get some water in your tank from the constant temperature changes and the ethanol in the gas which draws water from the air into your tank and then it separates afterwards and sinks to the bottom. WATER = BAD. NO RACOR = POOR PLANNING! BAD PLANNING = PLAN ON BREAKING DOWN! ;)
