1972 sears 4.5 eska can't get to go up on high idle
hi, I've recently received a 1972 sears 4.5 outboard. it hasn't been started in at least 15 years. I don't know much about outboards. I've put a new spark plug took off the bowl and cleaned it. the choke was stuck on, got that working. put I fresh gas. the only problem is the gas I put in is 50:1 and know it's supposed to be 24:1. the problem I'm having is it will run and idle. it just will not come up on high idle. when I move the lean rich knob it doesn't make much difference, and when I take it from start to fast it doesn't make much of a difference. everything seems to be moving fine. i'm at the end of the little knowledge I have. any advice would be helpful.
MahtyMaht
Re: 1972 sears 4.5 eska can't get to go up on high idle
Have you screwed around with the high speed needle on the bottom of the bowl? You're not likely to get away without a carb rebuild. The carb needs to be taken apart and ALL the passages cleaned, new fuel pump element, etc. You don't post a model #, but if you have the year right, it looks like a 217.59462;
http://www.searspartsdirect.com/par...247/1305320?pathTaken=&prst=0&shdMod=21759462
Get OEM parts here;
Results for Eska - Sears / Ted Wms
or call these guys with a model #;
VinParts
That motor has a water pump, too, and you should replace the impeller.
Get OEM parts here;
VinParts
thank you, I set the screw at the bottom of the bowl a turn and a half off closed, and I haven't tried adjusting since, so i'll try messing with that. I've never tried a complete carb rebuild before, I guess it's time to learn. is the water pump impeller hard to replace? thank you
and yes that is my model #
