Skifferskipper
- Joined
- Jun 13, 2011
- 35
Re: 1974 evinrude 70 hp won't rev in the water ???
Check the Stator....
Okay........ Just figured because I have a 1974 Evinrude 3cyl that ive been working on this problem with for about a month now and I rebuilt the carbs and everything your talking about right now then my step dad tested the diods somehow and said replace the stator.. Just used the boat all last weekend.. Sorry for interupting..
I think I am having the same trouble. I have spark with a hose hooked up, but when I put it in the water it still bogs down. I have not used a timing light out on the water yet. Did you figure out what your problem was?Re: 1974 evinrude 70 hp won't rev in the water ???
ok, finally got the boat back out on the water...... while at WOT running across the lake we shot the fuel mixture into the carbs there was no change unless you squirted several shots in there and then the motor bogged down.... also hooked a timimg light to the spark plug wires and it only came on with the middle cylinder.... that really didnt make sense to me, but i kept changing it around and the timing light only worked on the middle ?? any ideas with that ?
