1975 OMC stringer............. Pin Drive Prop HELP...........................
henry7o7
the other day I was out and out of no where the boat just rev up high. took it home and found out that the prop was the problem.. the hub busted.. its a pin drive prop.. the pin isnt busted but the hub is where the pin gos into. the prop it self is ok. how can i fix this? replace the hub? where can I get one?
Re: 1975 OMC stringer............. Pin Drive Prop HELP...........................
Ayuh,... Bring it to a Prop Shop, they'll decide whether it's repairable or not...
There's Nothing you can do, Diy-wise...
