1976 70hp Johnson
jblushadow
I am have an issue with adjusting my linkage. I originally had an issue where my engine would idle really high. So, I adjusted the linkage to where it would idle perfect. Took it out on the water and it would only go 5mph with the throttle on the hand control all the way down. I took it home and I inspected it with the handle all the way down and saw that the linkage wasn’t pushing the throttle anywhere close to full throttle. My problem is, if i adjust it to where it will go full throttle my engine will idle really high and probably won’t even cut on. Any thoughts on what to do? If anyone is interested I would be willing to do a video call to help show you what it’s doing. Thank you!!
