1976 Sea Ray SVR 220 Overnighter 4 bl Holley Carb
ibcarhamy
Just had the engine rebuilt and just got it in the boat and everything hook up. It started right off but I have a small fuel leak in the carburator where the balance pipe plugs in. Any ideas for a fix? Also where do I find an ignition switch? Anyone know of a source? Can't wait to get it in the water.
nlain
Re: 1976 Sea Ray SVR 220 Overnighter 4 bl Holley Carb
If you did not build the carb that is your next project. If you did build it then the oring seal for the pipe is bad, cut, going to have to replace the seal and that means pulling one end off of the carb. I take it you are talking about the pipe that runs from one bowl to the other.
