1976 SeaRay SRV200 HELP....
ArmyAdam
I have a 1976 SeaRay with a 302 V8 188HP. it has a merc sterndrive 888 that needs repaired or replaced it has water in the unit and griends real bad there is also metal flakes in the watery oil. any ideas on where to get a new/used one or repair kit cheep? I can be contacted here or @
Re: 1976 SeaRay SRV200 HELP....
Ayuh,... Welcome Aboard Adam,...
Don't be postin' email addresses on the net,...
The Spam will kill it...
'n it's against forum rules....
Fer the Drive,... Search SEI drives...
Haven't bought 1 personally, but I hear alotta Good talk 'bout 'em...
'ell of a reasonable price, with a warranty, brand new...
ArmyAdam
sorry about the e mail addy i didnt know and where do i find SEI drives?
ArmyAdam
I found this on ebay will they work on my boat? i hope so because i got them for dirt cheap i was the only one that placed a bid on them
You are bidding on a Mercruiser I/O Lower Unit Parts from a 1980 V8 motor as pictured below. These lower unit parts were functioning fine when removed from motor with a blown motor a few months ago and there were NO water or metal filings in the oil. There are NO pits, chips, or grooving on the gears. Both the Drive & Propeller Shafts are perfectly straight, and the bearing & seal surfaces are smooth. The propeller shaft has NOT been hammered to remove a stuck propeller.
Parts Included:
- FORWARD GEAR, 33 teeth (Good Condition)
- REVERSE GEAR, 33 teeth (Good Condition)
- PINION GEAR, 20 (Good Condition)
- PROPELLER SHAFT, 15 splines (Good Condition)
- DRIVE SHAFT, 13 splines (Good Condition)
- SHIFT SHAFT, 6 splines (Good Condition)
- CLUTCH DOG (Good Condition showing No wear)
- PROP SHAFT BEARING CARRIER (Good Condition)
- SHIFT CAM (Good Condition)
- ALL BEARINGS & SHIMS (Good Condition)
- WATER PUMP HOUSING (Good Condition)
These lower unit parts should fit all 4, 6 & small 8 cylinder Mercruiser-Two's from the 1970's up to 1982 that have the spring loaded tip on the end for the driveshaft. They will NOT fit the newer Alpha-One series outdrives from 1983 up to 1990's & 2000's and the huge TR outdrive series for large V8's from the 1970's or Mercruiser-One's from the 1960's.
These parts will be oiled down and packaged securely for safe shipping.
ArmyAdam
I have also found this for $300 Rebuilt Stern drive came off of 1964 Thompson he said numbers were 90-32765 will this fit and how do i find the numbers for my lower unit?
Don S
Don't even waste your time thinking about buying a bunch of gears like that. Chances are slim they would fit your housing. Even if they did, you don't have the special tools to install them.
Iboats sells SEI drives, but I can't find the link, might just give iboats a call.
Here is the link to the sei site. http://www.sterndrive.cc/
ArmyAdam
how do i know what one I need? and i wouldnt install them id have it done
ArmyAdam
tytytyty how did you figure out the gear ratio?
ArmyAdam
How many HP does the 1976 Ford 302 have? i cant seem to find out for sure many places say different things
ArmyAdam
well crap how can i figure that out?
and this is what the guy said about the gears i got on e bay for 20 bucks is he correct?
The gear ratio changes in the upper unit not the lower unit.
So, all the lower unit gear ratios are the same and will fit your
motor.
If payment is made today, I will ship first thing in the morning.
Thanks
Don S
In your original post you said it was an 888. An 888 is 188 hp, the other hp ratings were called something else, not 888.
ArmyAdam
ok ty was the guy right about the gears being the same on bottom and that the top is where the ratio is changed?
Ayuh,.. That is Correct...
ArmyAdam
well gears showed up best $$$ ive spent but the bad part is the top was junk as well looks like a tooth broke off and got stuck. it sheered all the gears off. I found a guy in Tiffin Ohio that had a rebuilt 888 that he sold me for $480 WOW what a find. put it all together last night after some fighting with the shaft and put it in the water today... runs like a dream after a few minor adjustments on the idle cable and stearing cable. now i just have to get a new exaust riser boot mine is leaking a bit and all will be good. anyone need the lower gears and shafts for a merc 888 stern drive let me know. Ive got a 3 year warranty on my unit and dont want to store them for that long.
