1978 evenrude, cylonoid or battery
wd9373
The boat will start if you jump across the cyloniod and some of the time the cylonoid will kick the starter over. if you run from the hot wire to the key post and turn the key it will kick the starter up a little but not enough to hit the flywheel. I also bought a auto cylonoid, dont do that. I got nothing.
rickdb1boat
Re: 1978 evenrude, cylonoid or battery
If it starts when you jump it out, you need a new Marine selonoid. Don't know which automotive selonoid you have, but it's always best to use a approved marine one.
