1979 Baretta Bowrider
Falcon65
Throeing this out just bought this for $100. Has a new Power trim, and stern with new prop. Starter was bad and floor is rotted down to foam. Are there any manuals fort this Critter? I have found some on the Mercruiser 140, starter resembles a chevy but not sure about the motor aren't marine motors run opposite of car motors? This show how much I know about boating.
todhunter
Canoeist
If you're looking for the boat's manual, it's probably nonexistent.
If you're looking for the engine and/or outdrive manuals, post over in the Mercury MerCruiser Sterndrives & Engines forum with your engine and outdrive serial numbers (year/make/model of the boat is irrelevant) and someone should come along and tell you which MerCruiser manuals you need to purchase.
Before spending any more money beyond the $100 you're into it, make sure you can get the boat and/or trailer registration transferred to your ownership. If you only got a bill of sale, some states make this process easy, and some make it difficult.
Also...here is some of the secret lingo used by some folks selling boats. This isn't always 100% accurate, but use this info to brace yourself / be cautious when you buy boats and boat parts in the future:
Bad starter = blown engine, cracked block, or some other mechanical catastrophe. As the buyer, you won't be able to hear it run with a "bad starter".
Soft spot / bad floor = waterlogged foam and rotten floor, stringers, bulkheads, and transom. AKA, this will likely be a full gut/restore for the buyer.
Runs on trailer = the engine will idle and run under no load while on the trailer, but there is some problem that will prevent you from accelerating when in the water.
New floor installed last season = likely a deck-over, AKA, they didn't remove any of the rot and slapped new decking over the disaster below to hide it.
Falcon65
Sounds like this one to a Tee soggy floors and all but I figured for a $100 the trailer and all the new propulsion is worth that. History was husband and wife owned it and 5 years ago both passed in a vehicle accident. Set for 5 years uncovered. For mr just sometuing to toy with. Got starter on and did compression check had good numbers all way across. Get deck done and figure how to run water to motor so won't overheat and give it a shot
