reiddo1
- Joined
- Jan 17, 2012
- 166
I have recently acquired a 1979 Sea Fury 216 and have a question regarding an exterior factory hole on the starboard side in the cuddy area. It is about one inch in diameter and appears to be a drain from the cuddy, but because it is so close to the waterline, I am concerned the boat will take on water in deeper swells. I have seen this hole in the same location on pictures of other Sea Fury 216 boats. Contact with Glastron hasn't provided good information. Their response is that in the older boats some scuppers were provided in the bow area but they were not definite with respect to this boat. I have used a fiber-optic camera kit to look into the hole from the outside and can clearly see the inside of a corrugated plastic pipe going to the cuddy but I cannot find this line inside the cuddy with the seats removed. Can anyone enlighten me on this? Is is possible it is a scupper which will only allow water to drain from inside the boat to outside but not the other way around. Thanks for reading................................Don
