1979 Stinger 75hp Exhaust cover gasket
Had the motor running on the muffs been trying to figure out this miss an low power. Looking at the exhaust cover i can see a small beed of water running down the side of the cover so im sure that gasket is blown. From the research ive done there is 3 gaskets in there i think? My question is the bolts on the outside do these bolts run all the way through or are there 3 sets of bolts i am going to have to take out. This will be the first time ive removed an exhaust cover any info will help.
There is one set of bolts.-----And these covers will be warped / distorted somewhat.------You need to correct that too.
thanks for the help guys for some reason I was thinking once I pulled that first cover there would be another set of bolts behind it to remove the second cover.
