1980's Mercury 4.5 stops streaming water....
raymondwhite24
I am having difficulty getting my early 80's 4.5 mercury running right. I have replaced everything the engine needed to run correctly, and replaced the impeller after finding that the old one tore apart, and now I get a weak water stream that slows down and then cuts out after it runs for a little while
Has anyone encountered something like this before?
If so what was the problem/solution?
any and al help is greatly appreciated.
Ray from Vermont
cptrick3
Sounds like impeller pieces may be blocking the cooling system.
Ayuh,.... Welcome Aboard,..... I agree,.... Drop the lower unit, 'n back-flush from the t-stat housin', the in-comin' water line,....
Hopefully, you'll find All the missin' pieces of the old impeller,....
1980, What,..??
4.3l, maybe,..?? no 4.5ls,....
flipbro
I wounder if he means 4.5 hp?. And he's in the wrong forum
raymondwhite24
thanks for the help everyone I will try this after work tomorrow. Sorry about being in the wrong forum, first time posting.
