1981 Chrysler-made 4hp Sea King specs. needed!
seakingowner
I have a 4hp Sea King made by Chrysler in 1981
The info. on the plate is VWB52004C, and Ser.# 18X22096
I need to know the oil/gas mix ratio, the plug and points gap, as well as the required/recommended grease and lower unit lubricants.
If someone knows where I can find a simple to read manual that covers this unit I would appreciate it.
Also, where one might find a new gas cap suitable for use on the integral tank on this unit, as well as a suitable replacement prop. The one on it is in fine condition, but appears to be made of some type of resin or polymeric plastic. I would not mind one like it for it worked well for the original owner.
THANKS!
