1983 johnson 140hp v4
joker
This 1983 Johnson 140hp v4 outboard motor has been sitting for 11yrs. Would it be worth getting it check out and worked on? The last time used ran for a while went back to put boat up and would not start has been setting since.
Bob_VT
Re: 1983 johnson 140hp v4
Absolutely! Clean the carbs, clean the fuel lines, change lower unit oil, INSTALL a NEW impellar (regardless of condition), Check compression, check for spark. Go for it.<br /><br />Bob
