180American
- Joined
- Jun 9, 2006
- 6
My 1984 Mercruiser 3.0 140 (1984 Wellcraft American)ran great for last 2 seasons until this year. First day out we went for about a half mile at 3/4 throttle and it quit right now. Almost felt like the engine locked up or vapor locked. It barely turned over at first and after 5 or 10 minutes it started ok. On the way back to the dock at around 2000 RPM it did it again. I've drained the fuel tank, it was clean, blew out the pick up tube, checked the anti siphon valve, replaced the fuel line, checked fuel pump for pressure and flow, rebuilt the carburator, installed new elctronic ignition, replaced the coil, spark plugs, set the timing, replaced all fuel filters. After all this it does the same thing. In fact, it will idle and run forever in neutral and up to 1500 RPM in forward gear, at 1800 rpm it quits abruptly every time. I can also run it in the driveway in or out of gear at any RPM with no problem. Anyone want to buy a boat?
