1984 90hp Evinrude, looking for picture showing where wire from VRO connects
hetterbr
Hi there, as the title says, I am looking for a picture showing where the wiring connects that is coming out of the VRO. it comes out of the unit and is close to the starter, it is a half moon shaped plug, but i cant find what it should plug into. Or i guess if anyone can tell me if it needs to be plugged in. the engine does use the oil reservoir, i pump it a couple of times to ensure there is pressure in the line - this is what the previous owner told me to do. does this mean that i am priming myself and whatever this should be plugged into is not required and that is why i can't find a plug for it? thanks, sorry did some rambling.
I do not believe the VRO on the 84 models had a " NO OIL FLOW " warning module.----So I would say the pump is a replacement and the warning module was never hooked up.
hetterbr
that makes sense. the wire is not long enough to hook into anything that i can find. Thanks for the help.
