1984 Scorpion 230 weight
rebars1
Can anyone tell me what the approximate weight of a 1984 Scorpion 230, 5.7L, Alpha 1? I need to get new trailer. Thank You.
Gary H NC
Re: 1984 Scorpion 230 weight
looking on NADA 2340 pounds,not including fuel ,gear and trailer
TK
My Chris Craft Cutlass 22' literature states a wt. of 3400#, maybe this will give you some guide lines.
cobia-boat
I have an 83 230 scorpion. And I was on a site and it stated 3,550 lbs. dry weight.
rebars1
Thanks guys. I hunted down the guy I bought it from who said it weighed about 3600lb when he had it crane-launched at a pier. Fully loaded, without trailer.
I have a 1884 230 Scorpion XL Stinger and it weighs in just under 4000LBS with gear and some gas. I know from experiance that a bunk trailer is the only way to go .I had an EZloader .Not so EZ let me tell YA . I built a new tube frame bunk trailer for it last summer and am over joyed at the results. I copied the Heritage tube frame trailer my Dad has under his 1983 230 Scorpion.
rebars1
The trailer that come with the boat is a bunk style, but is pretty rusted out and needs replacing. Since I will be mostly in salt water, I'll try to get galvanized one. sounds like I should avoid the roller type.
