solarismike
- Joined
- Aug 19, 2019
- 11
New to boating. Bought a Marshall Trihull 15 ft with 60 HP Mercury. PO said it had been out of the water for about a year. Carbs look great inside following a little seafoam treatment. First trip out would only run in lower speeds. Running up throttle caused engine to "bog out" and stall. Today the engine simply stalls when put into forward gear. I determined that the lower cylinder is not firing. Swapped coils, no change. It does have spark but pulling the plug results in no change. Thoughts?
