1985 AQ260A Impeller Kit
Yegboats
volvo supersession chain is 875811 >3862281>21951346 cross refs are Sierra 18-3081 Jabsco 1210-0001 Johnson 09-1027b These impellers should have 12 splines, 12 blades 2-1/4" diameter 1-1/4" width 5/8" shaft diameter with a brass insert
876120 is an active volvo part# cross refs are Sierra 18-3287 Jabsco 22120-0001-p This impeller should have 12 splines, 12 blades 2-1/4" diameter 2" width 5/8" shaft diameter with a brass insert
Mookychew
Hrmmm, so perhaps I'm going to need to pull the old impeller first and measure it up?
