1985 bayliner capri shift/throttle control
JAL51974
I took it all apart, original equipment to replace the vinyl on the side piece that the control is bolted onto. Now I cannot remember how it goes together. The shift cable box bolts to the wood of the side piece by means of a square plate. I cannot tell which way that plate is oriented to the shift cable box. Anyone have a picture or diagram or a description that I can use to put this together? I can take picture if needed. Thanks.
Joe
Ayuh,... Post a picture of the controller, so We know what yer workin' with,.....
Bayliner don't build 'em, somebody else does,.....
JAL51974
Will take pics this evening after work. the number on the cable box was 4E1522438 with no other markings or codes.
JAL51974
JAL51974
I thought I had it together but now there is no neutral. Throttle gives it gas but that's all. Any ideas are appreciated. Thx. Joe
