1985 merc 9.8 trouble shooting
Flyguy39
I acquired a boat and merc 9.8 from a trade. However the merc wasn’t running. The guy said he was able to get it to fire up but wouldn’t idle. I haven’t been able to get it to fire up. Seems to have decent spark and looks like it’s getting gas. Any one have any experience with these engines I don’t know all that much about outboards worked on dirt bikes mostly.
Any help would be great!
thanks.
QBhoy
First thing to do, to rule out anything serious or to see if it’s worth carrying on with the simple stuff....is to do a compression test on it. Rule out anything serious.
All being good...get the carb off it, clean out...new plugs and fresh fuel mixed at 50/1. See how she goes. Not much else to go wrong. Failing these common things..look at the pump diaphragm.
Wiring insulation can be bad on these and crumbles off.-----Top crankshaft seal is often loose on these.----Top crankshaft bearing housing can work loose.----O-ring on driveshaft is often forgotten.----Water pump impellers are not robust and need regular replacement.
