I have a 1985 Ranger 350-V with a 1985 Mercury 150hp Black Max which is new to me. When I purchased the boat I was told that there might be some bad gas in the 6 gal tank. (It has 2 tanks, 1-14 gal and 1-6 gal) the other tank was empty. Took it to the lake and it was hard to start and would not idle. Got home and pulled the plugs and they were solid black. Cleaned them, replaced them and everything seemed good. Ran new non-ethanol premium gas @ 50-1 mix and a can of seafoam. Ran ok but still fouled the plugs. Bought new plugs and installed them and then I messed up. I thought I was filling up the 14 gal tank so I poured a quart of oil in the tank before I filled it up. I was filling up the 6 gal tank and had put too much oil in the tank. Filled up the other tank correctly and went to the lake. Ran better but when I pulled the plugs still fouled. Pumped the fuel from the 6 gal tank into the 14 gal tank and filled it up with non-ethanol gas again. Pulled the plugs this morning and fouled again. Clean them, replaced them and put the muffs on the motor. Starts right up, purrs like a kitten but I know the plugs are going to be fouled when I run it all day. Side note: She absolutely screams across the water, she just doesn't want to start easily or idle!
Any ideas or suggestions?
Please!
Please!
