Hey everyone a friend told me about this site and wow what a vast amt of knowledge is on here......amazing
Quick question i bought an old 1958 SA and from what i can tell has barely been tampered with maybe some carb and ign tampering at the most.....the unit has good compression and all the ign stuff looks to be mint.....i cleaned the points with a small piece of 600 grit some fresh gas and bam it started after the second pull....it runs at slow and idles very well....i tried to put it up to the fast position and it doesnt wanna pick up speed...heres the thing once i turn off the fuel while its running as it near empty in the fuel bowl it has no problem doin fast.....heres what ive done so far
Complete carb cleaning
did a reset on the carbs adjustments they were right outta wack
cleaned the points
wondering if anyone may have come across this kinda issue
im think once u reset the points and replace a new plug/gap it might sort out the issue
any help would be greatly appreciated
cheers
cleaned the points
cheers
