Re: 1986 16' Bayliner Capri with a Force 85 hp motor
Congrats on the new boat,MrNo! They can actually be a bunch of fun to restore,and it sounds like you got one heckova deal!<br />Did I understand you to say,you have never had a boat before? <br />If not, some basics to save you some money.<br />Don't try to start it out of the water, or off the earmuffs. The impeller will be damaged in less than 30 seconds.<br /><br />Buy a grease gun and an impact driver,some outboard gear lube,and a drain pan.<br />Remove the vent/fill screws for the lower unit, and drain it.<br />It should be a greenish or black oil. Run your finger thru the lube to feel for chunks of metal. If the lower unit has water in it,or grey,streaky lube,it is leaking, and should be repaired before taking it out.<br />If you find water in it, don't think you got a bad deal. This is one of the most overlooked causes of lower unit failure there is. And it isn't uncommon.<br />I hope she is green or black,but if not,it isn't a biggy.Just don't run it like that.<br />If the boat has sat for over 6months, drain the fuel from the bowls, and clean out the gas tanks before attempting to start, and do a compression test, as has allready been sugested.
