1986 e-rude 25hp kill switch
boydog40
electric start, no spark on either cylinder, lanyard etc is on the control box
want to run down the kill switch wire first then on to the power pack etc
where is the kill switch wire on the block? is it the black/yellow wire going into the power pack?
if not please advise
thanks
saltchuckmatt
Easiest thing to do, is unplugged the big red plug and jump start your outboard back the motor. That will tell you if it's somewhere else like the control box or the wiring harness.
You won't be able to shut your motor off the regular way but there's multiple ways you can shut it off including plugging the red plug back in if the problem is up at the box.
