1986 Four Winns Candia 170
KenStager
This boat has power steering. While holding the steering wheel while underway you can feel it wants to pull left. Let go of the wheel and the boat goes left. Not a wild turn but certainly changes direction. Is there a balance adjustment of some kind.
Ayuh,.... Welcome Aboard,..... What motor or drive,..??
Ayuh,.... Does the anode over the prop, on the bottom of the anti-cav plate have a fin on it,..??
If so, loosen it, 'n turn it to counter act the prop thrust,....
If not, get one with a fin, that clears the prop, 'n change it, 'n adjust from there,....
