1986 power head source
JVG1
I have a cracked power head
Anyone know where I can find a rebuild power head? I have searched the web. No luck
1986 black max. 175hp
Dukedog
Bass Boat Central, Scream and Fly, Face Book (high performance boating), Chris Carson Marine (Florida)... you may have to go up or down (150 to 200) on horse power and size (2.0 to 2.5) for a replacement?.. jus do ya research on anything, anyone ya might find!!!.. lotta butt-heads out there now days.
would help to know where you live. plenty of rebuilders in every major location.
Chris1956
iBoats used to have links to rebuilders. I bought an inline 6 150HP block from one of them
JVG1
I am in California
Thanks for the recommendations. I looked online and did not find any that far back. Plenty from 92 and up. Nothing for 86
I will keep looking. Thank you
JVG1
What parts will enter change between the 150 hp and 175? I found a 150 hp
Both 86 blackmax
I will get serial number tonight
Thank you
Dukedog
justa 'bout everything BUT block half, pistons, rings, center main bearings (different crank) .. as for everything else ya gotta know tha difference, but can be used.. tha 150 is a 2.0 steel sleeve motor and your 175 is a 2.4 chrome (same as 200) bore motor which is tha MAIN difference
Faztbullet
None of the reman companies I know of even offer a 2.4 anymore...best bet is to find a older 2.4L Xr4 power head if possible. From the prices I have seen for a reman powerheads you may be better to part it out and buy a complete running 2.5 as prices are close to same.
JVG1
How does one identify the difference between a long shaft 1986 black max and a short shaft?
Chris1956
A short shaft motor is for a 15" transom. 15" transoms are found on Jon and aluminum semi vee boats 14- 16 feet and under. Likely Black Max's, being higher HP never came in that length.
Long Shaft motors are for a 20" transom. There will also be a fair number of Black Max Xl shaft motors.
Which length do you need?
JVG1
I will have to check. I believe it’s a 20” shaft
It’s on a 1987 ranger bass boat 370v
Dukedog
jfyi.. merc "letter" info for shaft lengths..
XXL..... 30"
XL........ 25"
L........... 20"
S........... 15" high performance offshore on V6
JVG1
Not finding much for power heads. Might have to get a different outboard or buy a new boat
