lakelover
- Joined
- Mar 26, 2003
- 4,390
I just bought a 1987 Chev. Celebrity w/ 74,000 miles (2.8L fuel injected) for my son to travel to college.<br /><br />He had trouble starting it one time, then a couple days later, I had the same problem. It would catch then die right away, only staying running if I pressed the gas pedal as soon as it started. Once it was running, it was OK. There was less than 1/4 tank of gas, so I stopped at the gas station to fill up. When I unscrewed the gas cap, there was a long rush of air being sucked into the tank. I put the gas in and it has run OK since then. It always starts right up when there is a lot of gas in the tank.<br /><br />Do you think I need to replace the vented gas cap, maybe that's why it had trouble starting??<br /><br />Thanks.
