PhilAtOmni
- Joined
- Aug 27, 2016
- 4
I purchased a 1987 Mercury 2 cylinder 35hp long shaft outboard, SN 0B177856, electric start with tilt and trim. Motor had been sitting unused for 3 years. Carb was rebuilt. I installed a new starter, replaced the entire fuel line from tank to fuel pump. Rebuilt the fuel pump, installed new plugs, removed and cleaned all electrical connections then routed and tie strapped all wires. Cleaned and filled tank with ethanol free fuel and measured oil. When put in the water, the motor starts right up, pumps water fine, but only runs on 1 cylinder until warmed up for about 10-15 minutes. Then all of a sudden the other cylinder kicks in and the motor runs perfectly, sometimes for a few hours, sometimes all day. What is the deal? Any help much appreciated. Thank you.
