1987 Mercury lower end removal
Doug4525
I have a 1987 mercury classic 50 45hp.I'm trying to remove the lower end to put a water pump kit in. I see 2 nuts and 2 bolts. Once I take these off is there any thing else to take off ? Do I need to take any shift linkage loose ? Does the lower end just slide out ?
Watermann
You have to take the trim tab off and then there may be another bolt under there as well on your model. Then it should slide off.
Top side above trim tab is plastic plug to get to bolt for trim tab
