I have a 1987 70hp Mercury on my Mariner recently if I go wide open it will cut out and stall after a few hundred feet, I thought it was a fuel issue so I put all brand new fuel lines on, about 30 bucks worth, I also installed new spark plugs, I even went as far as getting a compression tester, I got 90 lbs in each cylinder
I have a fuel selector switch which controls 2, 5 gallon tanks under the seat, today when it kept shutting down I tried selecting the other tank and it did the same thing
and after it shuts down its hard to start I have to give it like full throttle in neutral for it to start
the vents are wide open on the fuel caps also
I made this video today so you can see what I'm talking about, I didn't touch the throttle at all when it was shutting down
Mercury outboard shutdown - YouTube
I guess the next thing I'll try is to run a gas line from the tank to the motor, without the selector
