I'm testing this motor out before I buy it and found this milky mixture leaking from the top hole in the lower unit. While running the motor, it shoots clear water from the hole. When I shut it down, water runs out followed shortly afterwards by this milky mixture. Not sure this is a seal/gasket leak or an overfill situation? Is it a easy repair? Any advice/suggestions are greatly appreciated. the white milky mixture will also come out of the lower hole later on. Thanks!
probably a shaft seal below the water pump impellor....Easy fix. Water is mixing with the foot oil. Wouldnt run it too much till its fixed or you will destroy the gears in the foot
I appreciate your advice Chief Petty Officer. I think i'll make the repair and enjoy some fishing with my kids. Thanks for your service! From one prior military to another.
Where might be the best spot to find parts. Searched Ebay for shaft seal and having difficulty finding parts thru sears? Are there knock offs, other brands that will fit? Thanks
That motor is made by Force so those parts will interchange. Have you smelled it? Unburned fuel can mix with water and will run out like that which is perfectly normal. That will usually happen after it idles and does not have a chance to get to operating temp.
