1988 GM OMC 5L points gap???
hoytheld
Hello all,
I have all the stuff to do ignition tune up....
what is the gap for the points?
thanks
make sure to file the points with a points file or you can use your wifes nail file
use the gap as a rough set
use the dwell meter to get you dialed in
Lou C
the easiest way to do it is to hook up a dwell meter and a remote starter switch, crank the engine over while watching the meter, set it at the lower end of the dwell range because this equates to a slightly larger point gap; they will stay in spec longer.
