ZilligMarine0311
- Joined
- Jul 2, 2020
- 4
I am working on this motor trying to find the root cause of power loss that sometimes occurs under light to moderate load RPM for 15m or more. We are hesitant to run it at higher RPM with the problems we are seeing.
The water side of the cooling system is cycling water nicely, but the coolant side is showing signs of corrosion on the outside and the inside is corroded too from what I can see from under the fill cap. The temp on the outside of the exhaust manifold was 340F + and on the intake side 220+ right before he started losing power. I used a laser infra.
A compression test while cold got me 180/185 on all 4 cylinders but the oil pressure is fluctuating slightly while running. I'm concerned about the mechanical integrity of the motor.
