1988 O.M.C. 3.0
j.b. travis
I have A problem when I run the motor wide open It starts to lose mile an hour after obout 1minute also rpm. but if I back it all the way down and hit it again goes through same thing. no one thing it slowly dies down not just quite. thanx j.b. :rolleyes:
petryshyn
Re: 1988 O.M.C. 3.0
Measure the fuel pump pressure while under load, right at the carb inlet with a tee in gauge. This will verify a fuel supply issue...(restricted filter, tank venting, anti-syphon valve, air leak, kinked hose, fuel pump etc.) Since its runs fine briefly, its sounds like the float bowl level is being lowered when under load. :)
