1988 Yamaha 25HP Problems with tilt lever and shallow water levers
w2much
Are these levers intended to move freely on the tilt tube(clamp bracket bolt). These mechanisms are not operating correctly. They appear frozen in place on the bracket clamp bolt/tilt tube. Motor will not go down all the way unless I stick my hand under the bracket assembly to release the receiver assembly.
99yam40
they should move freely,
some are spring loaded in one direction
lever forces things in one direction ,
when yoou move the lever the other way the spring moves things back
w2much
The assembly looked pretty rusted and I was not real optimistic . A bunch of sprays with a penetrent and patience did the job. Both levers and functions are now working fine. Thank you for your reply
