rsollman
- Joined
- Apr 12, 2017
- 3
Trying to figure out if this is a common issue for this model of Celebrity. I recently purchased this boat and am still in the feeling out phase, my previous Glastron did not have this problem. The engine compartment has the fiberglassed stringers on either side of the motor with motor mounts. On the outsides of these stringers is a small space and then the walls of the flooring come down. I recently pressure washed the carpet in the boat and noticed this space between the floor walls and the stringers is holding water. I can't find a clogged drain anywhere either. Is this normal for this model? I've attached a crude illustration of the engine layout. The dark black lines are the stringers, the cross-hatched areas are the floors.
Everything is fiberglassed in around the entire opening / bilge so it's not standing water on wood or anything.
