Hey guys. I just purchased an 84 bass track. It has a 75hp chrystler on it. I checked the trim on it last night and it worked perfect! Then I took it to my mechanic to have some motor work done. I have a (transom saver ) boom stick that hold motor while driving. My mechanic told me to go up on the tilt trim. So I did that appartley the outboard saver stick was on there tight! So the motor was struggling to go up. Well the pressure metal piece popped out on the trim motor. Apparently when there is to much pressure it will pop out. We only found 2 pieces and couldn't find the snap ring. One of the metal pieces have a whole drilled through it with some orings the other is a little piece that goes on the end. Well we put it all back together filled it with 10-30 and now the up part is mega slow and won't stay up. When I go down it works great for just a push then stops. I hope this makes sense. What do I do?
