1990 evinrude 48 spl E48ESLESA
Portski
I have had so many issues with these motor now I have to disconnect the kill switch wire for boat to start , and plug back in to kill motor . Hard to start has new carb rebuild, new reed valves, new plugs, new gas tank, new power pack, new battery. New plug wires, new coil assembly, new gasket adapter to power head, Need help some odd things that have happed while motor was running and kill switch disabled from power pack I disconnected battery and motor still ran had to plug kill switch to stop motor. Also motor would not start so I took out 1 spark plug and boat motor fired right up put both spark plugs in won’t start.
I think you need to take starter apart / inspect / ohm check armature.------Don't rush out and buy a new Chinesium one !-----If motor does not crank fast there will be no spark.----Simple as that.
Portski
I do have spark just will not fire up get some small puffs of smoke and that’s about it
Portski
I did notice the drive assembly does not drop down always stays in gaged with flywheel I am not a master mechanic just trying to get it fixed
Portski
Got the beast running now have a wiring issues any thoughts from the experts attached a video
  • IMG_2408.MOV
