1990 Mercury 2.4 V6 175 - Water leaking from power head, exhaust adapter plate connection and rattle - when engine cranked dry - runs good no rattle.
OldGuy77
This started 2 years ago - since that time I have rebuilt the power head because the rattle was thought to be a rod bearing due to having had the oil injection fail. Then removed the oil injection and started using premix. The engine ran like a champ! No issues for three weeks then coming into the marina I throttled back and it started the rattle/knock. After conferring with several people the majority opinion was a rod bearing due to the oil injection issue most probably. Tore the power head down and after two separate visuals was determined there was no issue with the power head - it was in great shape. So on a suggestion drained the gear lube from the lower unit and it was striped. Appeared to have water inside. Under warranty so sent it back and it was either repaired or replaced. Since the power head was already dismantled decided might as well rebuild it - new rings - cyclinders honed - new rod bearings crankshaft seals etc. Engine ran great on cranking. Replaced the main gasket between the power head and the exhaust adapter plates. Put it back on the boat and when put in the water got water leaks and the engine stalled and died. Cleaned and regasketed both adapter plates, the exhaust tuner and driveshaft housing. Put it all back together and again the engine cranked and ran good. Put it back in the water and was right back where I had started. The engine was running, water seeping from the adapter plate, powerhead gasket area and possible the lower adapter plate but the engine didn't stall or die - and the slight knocking/rattle right behind the reed block was the same as at the beginning of this whole issue. Completely frustrated. Want to pull the power head and refurbish (glass bead most likely) the exhaust adapter plates. Regasket and try again. My opinion is that there is a connection between the power head, and or exhaust plate gaskets failing and the slight knock or rattle. And no there has been no sign of water in the two lower pistons. All suggestions and comments appreciated.
Chris1956
Honorary Supreme Mariner
I would not think that waterleaking from the powerhead base gasket area would affect running. That area also houses the cooling water. Is it possible it is overheating? Overheat can cause knock.
OldGuy77
Nope - it makes the knock/rattle immediatel even before the engine has time to warm up.
OldGuy77
My thoughts have been the water and exhaust leaks are possibly the cause. Think the problem is indemic to most likely the upper exhaust adapter and the power head gasket but could also include the gasket between the two adapter plates. To me its obvious I have compromised gasket or gaskets. Once I pull the power head plan is to reclean and check the mating surfaces for warps. Then find someone that can flat file them to perfection. Put a coating of permatex (the one thats recommended) new gaskets and put it back together and hope that treatment overcomes the problems.
Chris1956
You might check the powerhead for water leaks into the cylinders. Maybe an endoscope in the cylinders? Water leaks into the cylinders, can make it to the crankcase, possibly causing the knock.
Your ign timing is correct?
Chris1956
You might suspect the top main bearing of knocking. I do not know if you can check it by pulling the spark plugs and moving the flywheel checking for play, but you might try it.
Dukedog
ya on tha right track with tha adapter plates and motor mounts.. probably didn't cause tha "knock" though.. it probably isn't goin' away once it started.. need ta find out "whats" knockin' with a teardown.... could be a number of things but will only get worse and cause more damage as time goes on.......... jmo
OutboardBuddy
Is your top water pipe Grommet in good condition? What about your lower exhaust Tuner rubber seal?
If the latter is missing then that can pressurise the rest of the exhaust housing and Chuff water out through the top shock mount area.
Best
Simon Higham
Outboard Buddy
