1990 sunbird 4.3 omc cobra
bruceb58
Re: 1990 sunbird 4.3 omc cobra
Sundave,<br /><br />Don't post your question 3 times with different titles. It's not going to help you get your question answered at all.<br /><br />I would suggest buying an OMC manual first. Don't buy the Clymer manual. <br /><br />Read this link next:<br /><br /> http://www.hastings.org/~stuart/cobra/ <br /><br />Do you have experience pulling off your outdrive? You will need to do that to replace the cable. <br /><br />After reading Stuart's article you will see that there are two ways of setting the shifter bellcrank angle at the drive. One is to use a square and the other way is to rent a tool from your local dealer. <br /><br />I would also suggest renting or buying a drive alignment tool. This will align the gimbal bearing and the engine coupler.
