ReidMarsh
- Joined
- Aug 17, 2017
- 1
I am hoping there may be some input to this minor situation I have discovered. I have a 1988 Edson Avanti 17 with a 1991 Mercury Black Max 135 and the Prop is a Laser II 21P. The engine overall has been really well maintained and is clean as a whistle, starts up cold or hot as expected without issues for the most part and would consider the engine to be "Excellent" condition if I had to rate it.
Last summer I had noticed that upon occasion, not very often... the boat would BOG on the hole shot, with only myself, but once up and running was smooth as ever, the guages all look good and never misses a beat. When I would try pulling one of the kids skiing (100 lbs), I noticed I was running into the BOG each and every hole shot, and would have to feather the throttle up making a slow tough pull on them. I considered the prop but seems to be a pretty good overall performer and as mentioned gets up and goes more often than not without issue.
I run SHELL V Power (no ethanol), use Shell Nautilus Oil and had replaced the plugs with the oem spec and still the BOG rears it ugly head occasionally on my own and always under load with a skier.
P.S. The engine still has the factory Oil Injector, this will be removed this season.
Any thoughts would be appreciated!
