1991 Johnson 120hp V4
Brayan01
I have a 1991 Johnson 120hp V4 outboard engine.
Last year it worked very good, however this year I’m experiencing some problems with it.
It has 120 pressure on every cylinder. When I started it recently it works but on one of the cylinders the plug has turned black. The engine does not work properly and it shakes.
It has a new water pump .
Please let me know if you have any ideas on how to fix this. I would really appreciate your help.
Thank you,
Brayan
A black sparkplug indicates a cold running cylinder.-----Perhaps one of the carburetor floats has an issue.----Note ----Carburetors on starboard side feed the cylinders on the port side.
Brayan01
Thank you! I will start from there and keep you posted if I have any further questions, your help is much appreciated!
