1991 OMC Cobra 3.0 drive shaft seal removal?
jwdub
Hi Group,
I'm trying to replace the drive shaft seal that is just in front of the gimbal bearing. I can't seem to get a tool in there to pull it, any tips or tricks any of you have used in the past? I tried to use the same puller I used to remove the gimbal bearing but there does not seem to be enough lip to catch on the front side of the seal.
I searched past posts to see if I could find this topic but did not find anything on this seal removal.
Thanks,
JW
