kt7panther
- Joined
- Jul 16, 2011
- 3
Help!! I have an 1992 Evinrude 48 special in which the manual tilt went bad. I had to cut the rod of the old tilt but am having trouble getting the top pin out. The top pin has a cotter pin which I removed to allow it to slide or be driven out however where the pin is makes in nearly impossible to strike a punch on it. The pin has a flat head on the other side which has a threaded hole. Is there a tool designed to remove this pin? How do I get It out? Thanks.
Kenny
Kenny
