1992 Fisher 19' Bass Boat
mallarddog
I was thinking about purchasing this boat for about 8,000 Canadian. I would appreciate any info. on this boat, I am pretty green when it comes to bass boats. The boat has a 125 merc.
roscoe
Re: 1992 Fisher 19' Bass Boat
And your question is...?
roscoe
$8000 Can, roughly $5300us. Sounds good to me. <br />The boats are nice, solid, spacious. Aluminum hull?? 1992??? does that year and model have an all aluminum floor? They used to, and they were worry free as far as floor rot goes.<br />My Spectrum boat is based off of the Fishers welded hull. <br /><br />In the late 80's, Brunswick (Mercury Marine) bought up a lot of boat makers, including Blue Fin Spectrum, Bayliner, Sea Ray, MonArk, Astro, Starcraft, Fisher, ProCraft. In the late nineties, Fisher and others were sold to Tracker Marine. <br /><br />I would of course be concerned with the condition of the boat, but more concerned with the motor.
mallarddog
Thanks for the reply. I haven't looked at the boat yet, figured I'd get some info on it first. The motor is a 1994 115hp Merc. Not sure of hull or floor type either.
ghostrider
Hi Mallard! I bought a '95 Fisher SV 19 GT last November and I'm thoroughly satisfied with the boat. The hull is all welded and the only wood in this boat is in the bench seat and the transom. Storage is more than adequate. The boat is solid and performs. The day I test ran the boat the lake had already started to ice, was windy and white capping. The guy said we should consider another day because it was rough. I told him these conditions are what I prefer to test the boat. I felt if the boat could perform well in those conditions, fair weather would be a piece of cake. This boat is powered by a Yamaha Pro V 150 which is the max hp rating for the boat. What model is the boat you're looking to purchase? If you take it out for a test run, run the hell out of it. Take it out of the water and keep it on an incline to gauge how much water comes out. Turn the bilge on and gauge how much water comes out. There should not be a lot of water if you don't use the live wells and your bilge should be dry on a test run. Have the motor checked unless you can do it yourself. Good luck and Happy boating! <br /><br /> :cool: Ghostrider
mallarddog
I was just informed the boat is a 1989 and the engine is 1992, aluminum hull, and the price just went up 500 bucks!
11 footer
I hate when the price go's up. If you really want if you should buy it soon before it happends again.
snapperbait
Been a while since I've seen one, but I think they are both welded and rivited..<br /><br />Welds in the transom and some other areas, and rivited ribs..
