hungupcity
- Joined
- May 10, 2019
- 3
I’ve got a 1993 20hp mercury motor that has fire to both plugs, will idle but kinda sputters like it’s not a smooth idle, and will run half throttle, but when you go to throttle it full speed it just bogs down. Seems like it’s not firing right?
Ive checked the basics.
Checked the bulb on fuel line and also the fuel tank vent.
Took carb apart and cleaned carb. ( wasn’t dirty)
changed the plugs and checked gap. Used a inline spark tester to verify spark to both cylinders.
Did compression test when motor was warm and both are getting 120 psi. 100 psi when engine is cold.
Took coils apart and inspected for any damage.
Should I take fuel pump apart and inspect it?
Could it be a switch box problem?
Should I get a timing light and check my timing at the fly wheel?
Thanks in advance.
Thanks in advance.
